GPU for 4 monitors
I am looking for a GPU that can run 4 monitors all at once on one card. I will not be running games off of it nor any graphical incentive applications, just need the extra work space. Any one got an recommendations? Also the cheaper the better.
Any modern card with 4 inputs would work
750ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814487025&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Desktop+Graphics+Cards-_-N82E16814487025&gclid=Cj0KEQjw5syiBRCwxPbE6o_MsK4BEiQAUowjpsjTl5EcjJmUca-_7B2IdDXAuCmuFTJNs7vRaGJ_R40aAkvS8P8HAQ
r7 265
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150719&cm_re=265-_-14-150-719-_-Product
If he isn't running games you could probably even go cheaper.
Remember too that DisplayPort can support up to three displays from one connector through a hub or daisy chaining.
Wouldn't go too cheap though. What he posted would be pretty safe.
