I'm working on my first build and have run into a problem concerning my gpu fitting into my case.
GPU is the Sapphire Radeon R9 280X Vapor-X TRI-X OC
http://www.amazon.com/gp/aw/d/B00IPZW686?cache=af565f22ba50fb7489f741488...
Case is a refurbished NZXT Phantom 410
http://m.newegg.com/Product?itemNumber=N82E16811146122
I have conflicting sources about the length of the GPU and was wondering if anyone else has the same parts and if there were any issues fitting the GPU into the case. Thanks!
You will have plenty of Room for that card to fit into the case. The case is over 20 Inches long, even with the hard drive bays the card should fit! :)
Yep, it should fit just fine. Phantom 410 has 12" of space if you don't install a fan, and the card is only ~10.5 inches long.
Haha, oh I thought you already bought them, yea your fine on it fitting. Btw you did double post.
Thanks you guys! It appears pcpartpicker lied to me then.
See, that's the problem I ran into. The Sapphire website lists the dimensions as 308 mm, while clearance is 305mm. Where did you see 10 inches, out of curiosity?
