GPU and Monitor
So i have been re-viewing my build and i noticed that the monitor has only a VGA port but my GPU doesn't so should i get a different monitor or GPU? Any help is appreciated.  Here are the links: GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814130826 Monitor: http://www.newegg.com/Product/Product.aspx?Item=N82E16824236203
-Ianeo5
most modern gpu's come with a dvi to vga converter.
Ok ya i checked and it has one thanks alot!
-Ianeo5
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009436
