hey everyone, i'm having another issue with my ubuntu 15.04 install. I recently upgraded my GPU to a 7870 from intel iGPU, and have the proprietary drivers installed. I have done a fresh install since running the iGPU, so there are no conflicting drivers, but while playing games, i have low framerate even though niether my CPU, nor my GPU is running at 100%. does anyone have a fix for this? i'm really getting sick of windows.
yes, i am using the latest ones from AMD's website. i believe they are 15.2? I don't really want to use the open source drivers because they make my GPU fans spin at 100% all the time, and my ears start to bleed.
Make sure you're not using any hardware acceleration for flash player or your web browser ... I've had issues with it locking my clock speeds at pre-defined levels and not letting them reach their performance clock.
The fix was disabling hardware accel in my browser, and flash settings. If both of those dont do the trick try the desktop hardware accel too and see if that fixes it.
EDIT: The same probably goes for whatever video player you use.
Off the top of my head I thought there was settings somewhere to disable desktop composition in the window manager. It's been a good bit since I was digging around in Ubuntu to tell you where the settings are exactly.
What games? CPU and GPU being maxed out is not a must for games, and it isn't what you want in the first place. If they are constantly maxed out you will get stuttering and framedrops, something you don't want. So having a "buffer space" in the usage is a good thing.
Not very intensive games, intensive games are like Battlefield 4 or Witcher (neither of which are on linux iirc). And yes, when you scale up the res, the GPU usage will go up/
I dunno about a free demanding game. But if you said that with unigine it performs as it should. I dunno, maybe someone else knows what's the issue here. Besides the 100% fan speed using open source drivers, using the Radeon drivers does it performs as it should?
