Google Chrome not playing Adobe Flash Audio, Need Help
So I recently downloaded Adobe Flash Player 11.5 and now Google Chrome is not playing flash audio. HTML 5 works and so does Microsoft Silverlight, and I have flash audio when I am using Internet Exploer. I have looked at the mixer in Windows 7 to see if whenever I start Chrome that the volume is set to zero, but that is not the case.  I am wondering if anyone has ever had this problem, and if so how did you fix it?
I also have the latest audio drivers so that is not a problem either.
Check to see if your on a http or https page, You will find that many webpages dont support https flash.
