Good wireless headset for under a hundred dollars
Can anyone here recommend a good wireless headset for under a hundred?
Thanks
I bought the turtle beach x32 they are decent but require two AAA batteries. Fairly easy to set up the wireless antennae is USB powered, I plug mine into the back of the tv. It has two 3.5mm stereo headphone jacks that you can plug in your game audio. If you want to use the built in mic you will need a 2.5mm female to 3.5mm male adapter to plug into your pc microphone jack.
What would be a good set of wireless headphones with a built in microphone?
Wireless headsets are never really that good because of the wireless aspect, so don't spend too much. I saw some Nokia Bluetooth transceivers with a built-in mic and a 3.5mm jack for 5 EUR incl. VAT. That is just unbeatable. Even if you don't have Bluetooth, a USB adapter for Bluetooth costs less than 10 EUR, and you can turn any pair of headphones into a wireless headset with that solution.
