Hey everybody, hope you are having a great December.
I am looking to get a wireless headset that works on both my 360 and my PC that is wireless. I play lots of games with friends on Xbox and I play a lot of games by myself on PC. The problem is that I have to connect it back and forth between the two whenever I want to change and it is rather frustrating.
If anyone has a solution, I would love to hear it. Thanks!
Razer Chimera Wireless Headset. Plug the base into your PC and Xbox with different cables. Then you can just unplug what you aren't using from the base so that you don't have to do a ton of cable switching. You may be able to have them both plugged in and just switch channels back and forth, not sure. Amazon has it on sale right now though
http://www.amazon.com/Chimaera-Wireless-Gaming-Headset-Xbox-360/dp/B004TP9RN8
That sounds great, but I am going to hold off before I pull the trigger and see if there is anything a little more seamless.
You could go with the Creative Sound Blaster Tactic 3D Omega, you hook it to both the T.V. and the PC. It has a switch on the front to switch between the two. Plus its on sale.
http://www.amazon.com/Creative-Blaster-Tactic-Wireless-Headset/dp/B0058D8D3K
That is absolutely perfect. Thank you so much. Found a video that described how to set it up on both PC and 360 at the same time. It even looks like it can take audio from both at the same time! This is fantastic. I can't thank you enough.
