Good way to cheap graphics card
i need a very budget graphics card, it only needs to run very very lite games on 1080p, basicly it just has to handle 1080p, my budget is 50 euro's
start poking around on ebay for a GTX 660 or something like that.
a new option please
i like my stuff new because i have been working with old hardware for years
This is pretty much impossible when it comes to GPU's. Either buy an older card or raise your budget for something "new".
For 50 Euros and brand new, you will get garbage. Maybe a 250 or GTX 730 at the most.
Edit: Actually, you'll get worse than that. Just looking through the German Amazon page (not sure if you are from Germany) even a GTX 730, and an R7 250 are out of your budget range.
You guys just don't understand me, I don't need to run games, just stuff like Minecraft, and later I will save up for something better
I don't play it, but I googled min requirements and found:
GPU (Discrete): Nvidia GeForce 9600 GT or AMD Radeon HD 2400 with OpenGL 3.1
That budget you're not going to get much at all. Ask around at local stores for old stock. You'd get a very capable gpu 2nd hand ~ just saying... 6950/6970 etc.
Save up a bit more money and get a card worth getting. You dont want to cheap out on your gpu, you will regret it.
