Good USB Headset / USB soundcard
Currently looking for a usb sound solution below 35 bucks. Headset or DAC / plug adapter is whatever. I literally just need something to plug in for windows gaming audio.
IDK what is good. I was gunna get one or two of these out of convenience.
but I have yet to pull the plug as I need some more cash before I do so. Security being kept in mind here.
So, looking forward to hearding back
ty
Anker Soundcore Q20 (older model) sometimes go on sale for about $40. That’s a smidgeon over your budget, but they are a nice solution. Wireless over-the-ear headphones with decent sound quality, long battery life, and even ANC (noise cancellation). They have built in microphones for phone calls that seem to work fairly well.
Black Friday is coming up in a couple of weeks (if you are in the US).
Do you need literally just USB → Audio out?
If you do the folks at Antlion (ModMic) recommend things like this,
I need it to not sound like garbage
I’m going to assume they don’t sound like garbage since Antlion recommends things like that and their entire company is about audio.
For w/e just sound, those USB-no name things with some Realtek chip in them are okay-ish.
Creative refused to let these die, no idea how good (or bad) they are.
Yamaha AG03 or Schiit Fulla are better than motherboard onboard, and give you a knob (or more) for headphone volume so your hearing is not at the mercy of software fuckups. Blows your budget by a lot though.
Hmmm. I’ll think abt it. Probably do the thing I was gunna do and do one of those. Then I get a good audio line and I get another audio out and an it.
@MazeFrame they can refuse to let them die. I’ll refuse to use them xD had a logitech one that had really mad emi issues. You could dear the bus clock buzzing
Short rant:
HOW do companies using USB for data input, input stream and/or power not implement some basic filtering to keep the basic nasties out?
I am not talking about putting an isolating DC-DC converter in front of a linear regulator to get rock solid voltage. I am talking about 3 passive components costing not even 40 cents combined!
Because then instead of hearing the dmi bus go DEEEEDEEEDEEEDEEDEEDEECLICKSWISHCHITDEEDEEDEEDEEDEDEEDEEDEECLICKCLICKDEEDEEDEEDEEDEE
You’d hear your vacuum cleaner fans
yeah I just gave someone ptsd
