Good PSU for my build
Adding my old GTX 460 to my girlfriends computer but she needs a better PSU.
EPS12V needed for my board.
AMD 5800k
Asrock fm2a75 pro4-m
8GB Ram
HDD
GTX 460 1GB
Price range is about $60. Ill pay extra for shipping ect.
I was going to go with this. Rosewill Green Series RG630-S12 but I wanted to see what else anyone could come up with that might be better and maybe more (Future Proof)
Maybe this one. I not sure about the quality of Roswill Green series but SeaSonic S12II 520 is pretty good.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151094
I suggest getting the EVGA 500w 80+ Bronze. It is a good deal for about $50 or less.
+1 I own this PSU and it's great for the money. Most of the time you can find it for $30 after mail-in rebates and it comes with EVGA's insane warranty!
Yeah, it's a good budget PSU.  It's nowhere near the quality of Seasonic, but it should work just fine.
GTX 4XX series, them power hungry cards.
cx430 would suffice for the build. http://pcpartpicker.com/part/corsair-power-supply-cx430
You'd be very hard pressed to consume more than 300w @ load even if you had that APU heavily overclocked.
By future proof, what are the intentions for the system? Another 460?
Thanks for the help guys. Seasonic seemed like the best choice. I ended up getting the Seasonic M12II bronze 650w. Found one for $50 and it's modular! :)
Not a bad price.
