Hi,
I want to bluild a PC for my friend, he has 500€ and I want to know, if the parts would be good for games like Minecraft or something like Bioshock. It don't has to run in ultra settings but medium would be great.
Motherboard: Gigabyte GA-H81M-D2V http://amzn.to/U4efV6
CPU: Intel Pentium G3258 http://amzn.to/U9xME7
CPU cooler: CoolerMaster HyperTX 3 Evo http://amzn.to/1seBw5Q
GPU: Asus R7260X-DC2OC-2GD5 http://amzn.to/1oXchzN
RAM: Kingston KHX1600C9D3B1/4G http://amzn.to/1nxLJYb
HDD: Western Digital WD10EZEX Blue http://amzn.to/1qa8KU5
Case: Sharkoon MA-A1000 http://amzn.to/1qzXPPe
PSU: Sharkoon WPM400 http://amzn.to/1zBxZjZ
I know that it is below 500€ but he also has to buy the Keyboard/Mouse/OS....
Thanks for helping
I like what you have but I would go with this
(Edit at your wish) http://uk.pcpartpicker.com/p/VhHRYJ
If you want the keep the R7 260x
http://uk.pcpartpicker.com/p/DqvbTW
*Edit*
You may need a bois update for the Motherboard since the CPU is so new
better go with the fx-6300 , is gonna make a difference in multi-threaded games and and its a more powerful cpu than the pentium (stock for stock , oc for oc). Also for gpu you can search hd7850 , I have this gpu is one year old , but it is better than the r7 260x . If you can find it for the same money go for it. The cpu is gonna make a difference in the futute too. Also don't go with the the 400watt variant (I wouldn' go with sharkoon at all for a psu).
fx-6300
http://www.amazon.de/AMD-Hexa-Core-Prozessor-Socket-Cache/dp/B009O7YORK/ref=sr_1_1?s=computers&ie=UTF8&qid=1405373025&sr=1-1&keywords=fx-6300
mobo
http://www.amazon.de/Gigabyte-GA-970A-UD3P-Mainboard-Sockel-DDR3-Speicher/dp/B00F5R9O46/ref=sr_1_2?s=computers&ie=UTF8&qid=1405373042&sr=1-2&keywords=970a+ud3
This case better airflow
http://www.amazon.de/Aerocool-Strike-X-PC-Geh%C3%A4use-intern-schwarz/dp/B00606NC5S/ref=sr_1_9?s=computers&ie=UTF8&qid=1405371952&sr=1-9&keywords=pc+case
this ram is cheaper
http://www.amazon.de/Kingston-HX318C10F-Arbeitsspeicher-1866MHz-DDR3-RAM/dp/B00J8E91BI/ref=sr_1_16?s=computers&ie=UTF8&qid=1405372121&sr=1-16&keywords=kingston+fury
for psu go with the cx430m
for case not the nzxt one as it has blocked the front intakes. and its more expensive than the one that i recommend.
for keyboard go with a cheap one like a microsoft 600 or cheaper same goes for mouse. It will get the job done and you can spend the extra money on something else.The 30 euro you will save can go to the fx-6300.
For os I know that you can get os in some sites for less money. Does your friend have an old pc? if he does he can transfer the os to the new pc. If you do that , invest the total difference on the mobo and the fx-6300. Don't go with the pentium as you will need to change the cpu on the future for a better gpu , the fx-6300 can handle even an r9 280x when overclocked. The pentium will bottleneck. I have seen pentium(oc)+gtx760 and fx-6300(stock)+gtx760 both cpus deep the fps a bit , but the pentium deeps 5-15 fps (spefically in crysis 3,which eats cpu power for breakfast).
If you can get the os for free this is what you can easily get this
If you can't skip the fx-8320 and go with a fx-6300 and go with a cheaper mouse keyboard
I can sell you windows 8.1 pro 64bit key for 35euro (unused key)
