Any recommendations? Price isn’t a huge issue. But i want a company that supports the hardware and has some trust behind them. Some PoE ports would be useful, as would a managed switch in the long run.
At the moment i mainly have netgear dumb switches, they do the job but ill be needed something with more ports and more functionality to replace them.
There is the noise issues with that though, and lack of any more support for those switches. (though support is less of an issue over noise as long as its not vulnerable to something ridiculous)
Its awesome. Nearly silent, metal chassis. Low power. Non blocking 24 port gigabit switch. Only thing it doesn’t have is SFTP+ ports but no really that big a deal if you only use gigabit but needs a good amount of devices.
Note: it is not manage. This is only a layer 2 switch.
i have the managed version of it and it also works pretty well. I do not think mine has had a single firmware update since release though. Not a big deal but he did want something that was supported.
TP-Link are an option, but one that’s at the bottom of my list for various reasons.
Mikrotik look promising, not just because they are also fairly local. Software of their RouterOS for example looks extremely capable, and seems to have almost anything you’d ever need (they have a web demo).
i have a ubiquiti switch,cloud key, ap, and cameras. I enjoy the ease of use and support that ubiquiti offers. In my opinion if you want good features and long term support i would go with ubiquiti. Stay away from tp-link because of the support. Good switch but in terms of support it is lacking.
