Good Motherboard for APU budget Build?
Okay, so im building a Budget PC. Im going with a A10 7850K because there's a micro center by me selling a black edition for $130. I'm looking for a MOBO that is overclock-able, supports a minimum of 16gb of ram, fits in a Fractal design core 1000 case, has the ability to add a GPU in the future (Radeon HD 265, 260X used as place holder in part list) and that's able to support 1 of the three types of ram i have in the part list. EIther 1866, 2133 (or 2400 that i hear the Kaveri APU's can Handle). Now it doesn't have to support all 3 types of ram i listed, just 1 of them should be fine. And lastly have an HDMI port. Post in the comments what you come across. Thanks!
Build: http://pcpartpicker.com/p/2YmdN
The Gigabyte GA-F2A88XM-D3H is a nice Micro ATX motherboard which should support any of the RAM dimms you chose. I would get the G.Skill Ares Series 8GB (2 x 4GB) DDR3-2133 Memory as when you want to get 16GBs then you can just put another set in it.
http://www.amazon.com/GIGABYTE-GA-F2A88XM-D3H-Bolton-Micro-Motherboard/dp/B00FU829ZQ/ref=sr_1_1?ie=UTF8&qid=1393154734&sr=8-1&keywords=micro+atx+fm2%2B
