Good low price headsets
I am a streamer and I need a headset (for PC of course). Price limit it is $50. Any suggestions?
Not too sure on any particular model, but I always go for headset that are not USB input but mic and audio. Personally I always go Razer as that is a brand I trust and love the quality. Currently Im using a Razer Tiamat 2.2, Im not too sure how much it is where you are but it may be out of your price range.
Try to stick to brand such as Logitec, Razer, Roccat is all I can recommend.
Can I please get your detail so I can watch you streaming, Id be keen to see some!
For $50 you aren't going to get much of anything. The issue with headsets is that the manufacturer has to cover both the costs of a mic and headphones.
The cheapest headset I'd even consider is the Steelseries Siberia V2, which was $65 the last time I checked. The microphone isn't that great though, and is really only good for voice comms. I'd try to get the Logitech G430 if I were you.
I use Turtle beach X12s that I picked up for 35 dollars, and they have decent sound quality, and the mic is ok. But they are a bit old, and I am sure there is another model that is better. You are better off getting dedicated headphones and a usb mic.
