This is my Ideal Gaming Rig, I need to be reasonably priced but still play the new games smoothly. I just happened to find this parts from another thread and kind of pieced what I want together.
I looked at the video card and it should be fine playing newer games on ultra or high which is ideal. I don't mind going higher in price but it cant surpass about 650.
Yes the FX6300 is more powerful, but to claim that a Phenom II is not going to play modern games on Ultra/High settings is incorrect. My 1100T does more then well in every game on Ultra, your graphics card will limit you far earlier then a 965 will.
The FX6300 would work on that motherboard after you updated the BIOS, which honestly it is far easier just to get a better motherboard and cut the headaches out.
For the price you are paying for that GTX660, a HD7950 is only $15 more and would do far better. Even a HD7870 would beat the GTX660 and cost you far less as well so it is worth a consideration.
I would never recomend a CX series power supply, but since you are getting a combo deal with it what can i say.
The reason i do not recomend the CX series PSU's is i have had multiple CX series coil whine like stuck pigs. Check out the reviews on Newegg for more of the same coil whine issues that they bring(V2's included). XFX makes solid PSU's with much Amps and more warranty for equal prices.
Yes that mobo will work with the HD7950 or any card, you have to understand that folks are having issues with the FX based processors working on that board. Check out the reviews to see their issues, it might be something worth considering.
I'm trying to balance it out bewteen best buy and other stores. The reason is because I have a credit card; I don't mind spending as long as it's worth the cost. I'm trying to have a strong computer but can't spend too much.
Thank you for helping, I'll post result, I'm thinking 7950 with the gigabyte. I found RAM and a HD on bestbuy so I'm not too worried about that.
I'm mostly worried about the CPU, mobo and graphics and where I can get them.
That case comes with a 500watt generic PSU, try to find the same case without the psu included and save some money that way. You wrote you already have the CPU ram and HDD right? What are their specs?
Case, GPU and mobo are all the same just the PSU is different. Under $500, with the 8150 the HD7950 will do gaming very very well. Heck the 7950 overclocks very well also, if you want so save some money we can switch to a HD7870 and OC the heck out of it.
Yes definitely solid in my opinion, the HD7950 will do very well in gaming. Are you coming from console or a regular pc? If so, you will love the difference!
Well, I;m coming from both. My laptop was relatively weak and I'm going into 3D Engineering Design and my laptop wasn't cutting it. It also was slow on games and I don;t like the uncustomiability with a laptop. I also play alot of console, this will probably be my most proud build. With the help from mostly you and the few others.
I do not know what the requirements for 3D engineering design programs are, for gaming this is a solid build that will do well but for anything like you mentioned i do not know. Maybe someone can give their two cents if Nvidia card would give you more benefit in that type of program vs the AMD card.
I looked into the software and they both don't have problems but I think this should work. Honestly, I think the 3gb card should work. I don't know how much stronger you can get with the motherboard's compatibility.
