So I need a fan controller for my Prodigy (not enough mobo headers for even stock fans). So what is a good fan controller around $20? I want to have enough money to buy a 230mm Spectre pro as well.
There is the NZXT Sentry Mesh for $22 USD, I was planning to buy one but don't have enough fans in the first place to take advantage of it. It powers up to 30W on each slider.
http://www.amazon.com/NZXT-Sentry-Performance-Controller-Black/dp/B001E0JH5E
You can also look at a fan splitter, like this one.
http://www.amazon.com/Phobya-3-Way-Splitter-Single-Connection/dp/B004CLFOK4
This one is 1 to 3 splitter but there are also 1 to 2 even up to 9 (if you want to go nuts).
I have a couple of Y splitters but they only work well if you have the same fans or else I would get one noise fan and one quiet fan since 50% speed was different on the two.
Bitfenix Recon. Only requires a single drive bay. So it should fit your mITX.
I didn't have enough fan headers for my fans. I have a 6way braided cable for most of my 120mm chassis fans. I decided to populate all available mounts in my 600T. That would be a cheaper alternative.
Yea forgot about that.
