Good cheap-ish case fans
I don't want to spend a lot of money on fans so what's the best deal under 10?
More options are appreciated, as I can't get everything in Europe, and paying for postage does not seem like a good idea.
Are Arctic F12 good?
CM Sickleflow; you can sometimes get them for a couple dollars here in the US.
rosewill and nzxt
The fractal design silent fans are good cheap fans i use a cuple of the 140mm ones in my current rig.
There silent and move decent air and come with a bunch of accessories (low noise adapter/rubber mounts or  screw's to fit them ect)
http://www.amazon.co.uk/Fractal-Design-SILENT-SERIES-120MM/dp/B008K6CRDE
