Good build?
I live in Philippines so prices are a bit higher than other countries like US. I am planning to build a gaming or sometimes editing PC for projects (plus monitor, keyboard and mouse but I already have an OS) with a budget of Php 40,000. I usually play at 1080p and I want to play the latest games like COD: Ghosts, Battlefield 4, AC IV: Black Flag, and more.
Here is the PCPartPicker list so you can edit some parts (Don't mind the prices. Just look at the prices here: http://dynaquestpc.com/): http://pcpartpicker.com/p/26XTM
CPU - AMD FX-6300. Php 5,450
Motherboard: ASRock 970 Extreme4. Php 4,400
RAM: Crucial Ballistix Elite 2x4GB 1866MHz CL9. Php 3,950
HDD: Western Digital Caviar Blue 500GB. Php 2,400
GPU: Zotac GTX 760 Reference 2GB GDDR5. Php 11,000
PSU: EVGA 500B 80+ Bronze. Php 2,200
Chassis: NZXT Soruce 210 Elite. Php 2,050
Monitor: BenQ GW2255. Php 6,100
Keyboard/Mouse combo: CM Storm Devastator. Php 2,450
Total price: Php 40,000
I'd go with a Asus monitor for around the same price and spend a couple of dollars more to get a 1-2tb HDD, but yes its a good build. Besides you can always add more storage or a SSD later to speed up the system when (if) you think it necessary and have the money. Only other thing I can think about is depending on your local retailers there can be some really good deals on AMD HD7970's for similar money which are going to be a few frames a second faster, particularly if you add multiple screens\crossfire later on. But yeah, should game hard at 1080p, either max stuff out at 30fps or highish at 40-60fps, your choice.
(edit, can't find any better HD7970 deals at your retailer specified, but still check around elsewhere, may find one)
Don't need a 1TB drive anymore because my brother will give me his 500GB external for backup and I will install my very old 320GB Seagate Barracuda 7200.10 (yeah it still works). Wait. Sata III supports Sata II, right?
sata is backwards compatible yes.
i would personaly try if you can afford pickup a FX8320 with Asus M5A99X evo R2.0 or M5A99FX pro R2.0 mobo., the 8 core realy comes handy wenn editing.
About editing it depens on which software you use, if you use software like sony vegas that can use open CL as well, and you can afford a 7950 or R9-280X then do it.
