Good battery saving apps for linux
hey im currently running ubuntu gnome LTS version and im wondering on whats a good app or tool to help increase battery life?
powertop - it shows you what is using the energy and suggests optimisations (they are not persistent though)
sudo apt-get install powertop
tlp - Its configurable and applies powersavings when on battery but disables them when on wallpower.
 sudo add-apt-repository ppa:linrunner/tlp
 sudo apt-get update
 sudo apt-get install tlp tlp-rdw smartmontools ethtool
For setting up tlp that 2nd post on the askubuntu.com forum is a great source.
Original manual: http://linrunner.de/en/tlp/docs/tlp-linux-advanced-power-management.html
cheers ill see how long it lasts now after ive charged it up fingers crossed it works :D
Check with powertop if tlp applied the power savings successful. If some options are missing, powertop does show you what it did.. so you could manually add them.
You can even use powertop to put devices in powersaving mode under the tunables tab, or by appending
$ sudo powertop --auto-tune
in the terminal if a powersaving daemon like TLP doesn't make those changes automatically. TLP is a great program, the config file itself is well documented so make sure to read through it and check that all settings are fine.
Another program similar to TLP is laptop-mode-tools, got it installed after TLP couldn't control my battery levels anymore for some reason (I want the battery to start charging when it gets below 70% and stop charging when it hits 85%).
Also, here's a good intro to powertop:
