I need some advice on which am3+ mobo to get.
Thanks for any help!
Budget?
http://pcpartpicker.com/part/asus-motherboard-m5a78lmusb3
That is the best one I can find, and it will not do very well with overclocking that requires tweaking voltages because it doesn't have that kind of power regulation.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157292
Thanks guys, I'm just going to switch to atx. I wanted a smaller form factor build but its fine.
http://pcpartpicker.com/part/msi-motherboard-760gmp34fx
Much better options for the price, although neither of these have support for SATA 3.0, 6GB/s. This one, however, supports 16 GB of RAM at the 1866 MHz standard. It also happens to look singnificantly nicer, but that is simply personal preference. Although I would probably go ahead and stuff it with 16 GB of Patriot Viper 3 1866 MHz in black. That costs about $118 for that much RAM though...
If you need relatively inexpensive then, get the MSI A970-G46. It still isn't that great at overclocking with voltage tweaks, but it does support all the latest standards, really fast RAM support and SLI/Crossfire. If oyu have more money to spend, do please consider the ASRock Extreme9 990FX.
