So my CPU is an FX 8350 and my motherboard is a M5A99FX Pro R2.0
I want a decent air cooler, one that isnt SO big just a small one that will provide better temps than the stock.
I currently idle at 36 degrees Celsius and I havent tried games yet.
My RAM is corsair Vengeance (if the height matters). And my case is a Corsair 650D.
My budget is anywhere from $50 to $100
Thanks so much for reading and helping!
If you can, get the NH-D14. If you really can't, get the NH-L9a.
So I basically agree with the gentleman above, but the NH-L9i won't fit, as it's for Intel sockets.
It's a brilliant cooler. It's cools very well, has excellent contruction and a brilliant finish.
Hell, you could even do some light overclocking. Just don't go wild with it.
Cooler Master Geminii m4 is great. If you put your ram in the blue Dimm slots on your mobo you should be fine with clearance.
thanks, i didnt know that. edited my post... lol
Phanteks makes some pretty good coolers, the 12DX doesn't block any ram slots.
Phanteks PH-TC14CS CPU Cooler
Patented P.A.T.S (Physical Anti-oxidant Thermal Shield)
Patented C.P.S.C. (Cold Plasma Spraying Coating)
C-Type Single Tower Radiator
Five 8mm Copper Heat-pipes
Two PH-F140 premium fans
nevermind that's actually huge
