Good after maket cooler to replace amd 290 ref cooler
hay everyone so i have a amd r9 290 at the time i bought it only the trix cooler was out and it was $100nzd more so i thought ill give the reference cooler a try and get custom water cooled or a aftermaket cooler later.
my card is loud ish im getting a hyper 212 for my fx8320 to oc, and that would make my computer still loud.
iv seen the nzxt g10 bracket and some actric cooler ones 2.
i dont really want to spend alot for custom water cooled so i just want a good cooler for my card and so i can oc a bit to.
thanks everyone for the help.
The NZXT bracket has no VRM or RAM cooling on it and that is a good way to kill a card. As far as quiet aftermarket you wont have much luck unless you get a custom loop set up. Not for the faint of heart, and quite expensive compared to other options. You may want to make sure your card is reference (it should be) and hop onto Ebay to find an aftermarket cooler from another brand. Gigabyte makes good ones.
thanks
