I started game development using Unity 3D, but have moved away from there considering that to achieve somewhat decent visuals with the more advanced rendering options in the software, you'll have to throw in $1500 for pro, which I am not willing to do for a smaller project. For me, UDK is out the picture, because I don't like using the engine. There seems to be to much functionality by default, and it doesn't quite feel like coding in a 3D engine. (I haven't used the engine much, however) My question is, what would you consider a good 3D engine that I won't have to invest a large sum of money into using? Some good things I would like would be:
Minimal/moderate graphical interface (nothing over the top)
Ability to implement programming languages, possibly Java
Minimal amount of included assets
Affordable
Would this be too much to ask from a budget game engine? Am I better off just investing my time into creating my own game engine, or learning to use a game development framework such as libGDX? Much thanks in advance.
You could try Ogre3d, it is an open source game/3d graphics engine written in OpenGL. You can implement your own code inside it using C or C++ and it doesn't have too much of a GUI. You could look at the demos on their website to see if it's functionality is somewhat what you need.
It has mostly a lot of 3d rendering features, but also some basic game development related features like a map loader for Q3A maps.
another thing to consider is learning java programming, and then using LWJGL. its a game library that wraps openGL, openCL, and openAL. i haven't used it personally as of yet but am beginning a school project with it. Minecraft actually uses it
Unreal engine is now $19 a month and provides full C++ source-code access and coding in C++, getting rid of the horrid UnrealScript so this might change things for you.
Cryengine is your best bet. Free untill you need a licence to distribute which its the a % but you can negotiate depending on your game. Source code is now available. And while they have removed a lot of good features since 3.4.5 with the new "Cryengine" They did add new ones seeing as it is technicly a new engine.
If you're happy with just running with scripts, Their Lua implementation is fery powerful as well.
There's some documentation for it online but not as much as the 3d modeling aspect of the game. Upside is that within the same software you can develop your own assets and then put them into the game and assign them behaviors and set up particle systems as well as much more intensive simulations for games where it's required.
