i made a post for 1000$ build and now i can make up 1200$
i was thinking this http://pcpartpicker.com/p/HmlV
do i need a better motherboard to overclock
also if you have a better pc with the same case leave a link.
pc uses : sony vegas , gaming.
alright... at the 1200 price point you should be getting more for your money then this.
Sidenote: that case is... expensive. you really should have a very good explanation and reason for spending more then $100 on a case... ever. and that is a monstrous case... more well suited for a custom water system then a prebuild self contained system.
http://pcpartpicker.com/p/HniH
that will fit your parts... it's a much better MB for overclocking... and a better cooler then yours as well. plus the SSD will make this system more then worth the cash you spent. overall this system is a better rounded system for the cash.
In less your a intell fanboy I'd go with a fx 6300 and a Asus Mobo with 3.0 x16 pci express.
Take the extra money upgrage to a r9 290. Add another if you're planning go 1600p gaming.
^^ +1 with what Kratikos said !
for $1,200 i would go 6300, 290x, 16gb ram, SSD, etc
That's some old hardware in there. I'd go with an 8 core FX or a Xeon. Both should be good for gaming and video editing work.
The Xeon will be a very strong contender. However, it's not as overclockable as a K-skew CPU or a FX chip.
http://pcpartpicker.com/p/Wrt7sY
I'm sorry, but you guys are just sad..........
This post is nearly 1 1/2 years old!
Trolled myself. One off the bucket list.
P.s. dont blame me for being a tech geek at heart.
