GnomeGet: A python module and command line interface for managing Gnome Extensions
So here is my project for the 1 MONTH "Just do it" challenge/initiative:
I have been working on a python module and command line tool for managing Gnome Extensions. The goal is that the tool should be able to install, remove, update, enable and disable extensions from the command line. I was able to this thank's to this blog post by Nicolas Bernaerts.
The code I've written as of now is available on GitHub.
It is in development and does not have all features working yet. If you want to report a bug, submit a fix, submit a new feature or any kind of improvement, feel free to do that on the GitHub page.
Edit: All planned features should work now but it may still have bugs.
Will take a look. Since there are bugs I will put it as Almost Complete. Great work man. Really glad that you took(and completed) the challenge.
Also you should think about making a small Tek Wiki post which describes what you have achieved.
I am a complete tard and can't figure out how to make this work after 1 hour of digging about. Could you add installation instructions to the repo?
Fair enough, I called it that since I put it out without having tested it properly and since the main features (installing and updating) don't work yet.
I made a page for it, but I prefer to have most info on the GitHub page.
Sorry, I pretty much put it out as soon as it sort of worked, wrote a quick README and went to bed so I could not help you to get it working. It is indeed not fair to assume that everyone knows how to install python packages. I've written instructions on how to run it and how to install the requirements on most popular distros.
Thank you!!!! This works as expected now!!! Congrats on pretty much completing the challenge.
Great! Hopefully I will get installing and updating to work as well.
This would be amazingly useful. Right now I have to open Firefox every time I want to install an extension just because I'm a lazy idiot, but I'd prefer a more apt-get style approach to extensions.
@K4KFH Glad you appreciated the concept!
I just realized I forgot about search functionality so that's added now.
I've now turned it into a python package that can be installed with:
sudo pip3 install git+https://github.com/chmod000/GnomeGet.git
Just wanted to say (a day late) that the package has been renamed from GnomeGet to gnome_get to comply with proper python naming convention and that installing and updating now works. If you installed the package uninstall it with sudo pip3 uninstall GnomeGet and install it again with sudo pip3 install git+https://github.com/chmod000/GnomeGet.git. When you want to update the package, use: sudo pip3 install --upgrade git+https://github.com/chmod000/GnomeGet.git
Edit: ping @Atomic_Charge
Congrats you made on to the wiki :D
