GNOME Show Apps and Blur my Shell - Bug?
First of all I do apologise of the Title, but honestly I couldn’t came up with a better and condensed title for what I am experiencing, so again, sorry about that.
I want to mention also that I did try to look for this issue on internet but it seems I am the first one experiencing it, or at least reporting it.
Basically, I am on Fedora 42 on GNOME environment, and I have decided to do a bit of customization of the UI just to look it a bit different. So I have installed the Extension Manager, a bunch of Extensions such as Blur my shell, Just Perfection and Open Bar. Done some settings, by following some Youtubers, and I think I have achieved a pretty good results, at least for my tastes, but I have noticed a very weird thing with the “Show App” functionality - basically the button from the Dock that shows all the apps installed on Linux.
At the beginning no problem whatsoever, but now if, for example, I have another application opened, and I minimize it and then clicking on Show Apps and going into the app list, no matter if I close that view or I open another App, the previous minimized App automatically reverts back to the desktop and so It will be visible again. But it is not 100% true, and what I mean by that is, whilst I can interact with that app because it is already visible on Desktop, for Linux is still minimized, and in fact if I try to press the icon of the app from the Dock, it makes the animation like showing up from the Dock to the Desktop, but it is already visible to the Desk so is just an animation plus making the App window effectively active (if you see what I mean).
I think this issue is caused by Blur My Shell extension, because if I try to disable it, this strange issue is not happening at all. Now I am wondering, is it a bug? A known issue? Or perhaps there is a setting I need to change on Blur My Shell to make this annoying issue disappears? Anyone else did experience this kind of problem?
For extension issues it’s usually best to go to the extension’s homepage, which is frequently a git repo where you can review and report issues. You can find a link on the extension’s GNOME Extensions website page -
https://extensions.gnome.org/extension/3193/blur-my-shell/
In your example, I found a few issues reported that seem similar to what you’re describing.
One user suggests the following might resolve the issues for users, but it does involve disabling a feature you may have wanted.
Thanks a lot for your guidance, I will keep in mind that for the future. Yes, it’s exactly the same problem, but your assistance already provided me a solution because in one of those GitHub links you have shared, I found a temporary workaround to it.
For convenience, and for somebody else who might look for a solution to this exact same issue, I will copy/paste here the workaround:
A very simple bug fix, find “Applications” → “Blur on Overview” in the Blur my shell settings and disable it to restore normal functionality. After that, other blur effects can be turned on and set up normally.
