I don’t have a Nvidia card so it’s a little hard for me to give you good answers but try adding the following to your /etc/environment file:
CLUTTER_DEFAULT_FPS=RefreshRate
__GL_SYNC_DISPLAY_DEVICE=Output
Replacing RefreshRate and Output with the refresh rate of your monitor and the name of the output port for your high refresh rate monitor (find using xrandr)
I think there is also something about disabling flipping in the Nvidia settings but I can’t find where I read that sadly so just try and poke around in the nvidia settings and see if you can find anything related to disabling flipping.
Note: Make sure to reboot after both the changes to /etc/environment and after changes to nvidia settings.
Edit: Ugh, sorry for a semi-necro bump, I did not notice this was more than a month old
Just to add my 2cents:
I am running AMD R9 390 with amdgpu driver with xfce. (no wayland)
Per-monitor refresh rates work. I have 2 4k monitors connected but unfortunately this card can do 4k@60 only with DP, the second monitor is connected to HDMI running 4k@30.
It is super-noticeable.
I see the difference wile moving a cursor, windows, playing videos, running UFO test, etc. This is both with or without compositor enabled.
the only non-default/non-automatic X-config I have is this:
