Glorious Pc build
Hey I'm looking to build a cheap PC that will most likely catch on fire. I'm probably going to put a SILVERSTONE 1500W PSU, with a ZOTAC ZONE GTX 610 GPU, with an AMD 9590..... what other parts should i get?
Im also considering using this motherboard i scraped from a 2002 dell computer.... idk what kind of motherboard it is but it has ports ans stuff so ill make it work
Dude that psu is a piece of shit and under powered, You need at least 2000 gigawatts of power if you don't want that gt 610 to set on fire.
Oh no no no, really hope you are not serious.
1. 1500w, you need nothing close to that.
2. Gtx 610? Gaming is not going to be a fond experience.
3. 9590? Ehhh not exactly the greatest purchase.
4. That 2002 motherboard is not going to support the 9590, nor would I ever recommend an oem motherboard.
You seriously need to do more research before trying to build a pc, or else you are throwing money down a bottomless pit.
i called up the king and he said i was pushing my PSU to its limits, he said i atleast needed 1600 gigawatts, he said if i got anything less then my gtx 610 will explode. If i settled for an I7 my computer might explode while gaming. I heard on youtube that you can jam a cpu down any motherboard i want, and it worked fine for me. so your argument is invalid.
Sigh yet another terrible troll.
