i wonder if the rpi4 is supported by gitlab? I installed gitlab on my rpi3 a while ago but ram limitations made it impossible to have a good performance. So i went with gitea on my rpi3… but i really miss gitlabCI and i dont want to use jenkins etc. if i can just use gitlabCI instead.
Do you want to install gitlab or a gitlab-ci-runner on your pi or both?
4GB of ram is what gitlab recommends as the minimum amount of ram to get a good experience out of it. Deffinitely agree with that 2GB ram gave me ‘The application is not responding’ after every commit.
For runners its recommend you install them on another machine entierly. But it is deffinitely possible to install them on the same 4GB ram machine and have a good experience. It just wont scale much.
The new pi has 4GB ram so… get the 4GB ram pi and you should be fine.
I’ve got mine running on kubernetes ARM hosts that have 4GB of ram, (not RPI 4s, but something else) If you want to play around with it on a pi4, it’ll work just fine. I’d be concerned about the ci runners on the same unit though, you might want to grab a 2GB variant for the runners.
For light ci usage it can work. It worked fine for me at first. I had it build docker images once a week. That was really all. But now Im also instead installing the runners on my NAS at home (the gitlab is on digital ocean).
Really cool that it allows you that. Also makes the runners more portable (and I have access to all the stuff running at home). If you decide to you can move your project to gitlab.com and register the runner for the project.
Yeah, I’ve got multiple gitlab instances all connecting to my kubernetes cluster to run builds. We’ve got ARM and AMD64 on there, so I can do all the builds and tests I need across personal, volunteer projects, pet projects and professional stuff.
Mhh, i am currently stuck :s i added the ppas but when i tried installing gitlab it says that i am missing some ruby dependencys… but i have installed them all. I am also struggling building it from source.
Yes, thats the way it tells me i have dependency problems.
The following packages have unmet dependencies:
gitlab : Depends: ruby-rails (< 2:5)
Depends: ruby-pg (>= 0.19~) but it is not going to be installed
Depends: ruby-fog-aliyun (>= 0.2.0~) but it is not going to be installed
Depends: ruby-sidekiq-cron (>= 0.6~) but it is not going to be installed
Depends: ruby-kubeclient (>= 3.1~) but it is not going to be installed
Depends: ruby-rails-i18n (>= 4.0.9~) but it is not going to be installed
Depends: ruby-peek-pg (>= 1.3~) but it is not going to be installed
Recommends: certbot but it is not going to be installed
Recommends: gitaly (>= 0.129.0~) but it is not going to be installed
E: Unable to correct problems, you have held broken packages.
And dpkg --get-selections | grep hold shows nothing
As i said, it doesnt matter if i previously installed ruby dependencys
The fun thing about this is when I look on my install of gitlab install for ruby-rails
apt-cache policy ruby-rails
reports
Installed: (none)
Candidate: 2:4.2.10-0ubuntu4
dpkg also tells me I do not have ruby-rails installed.
Witch to me would indicate that similarly to how they bundle nginx with their omnibus install they do not actually use the ruby from your repos, but a bundled version that’s exactly what they need instead from their own repos.
So I’m not very convinced anymore that instlaling packages would fix that without trying it on a pi myself.
But things may be different on the arm builds. Since it tells you to look for that version try and find if you can install it anyways.
Community docker images would be an option, but the official one does not seem to support arm either.
