This 790 is missing a power supply and it’s battery holder
But I can use its proprietary power button and front panel connectors on a optiplex 7010 Mobo I have and it’s i2400, the heatsink has standard lga 115X mounts so it might be useful in another project
Might turn it into a Minecraft server, I don’t know what use it will serve just yet
Front panel is about 5 inches so I can probably mod it into a 5.25 faceplate, power button seems easy enough since it’s about the same size as a regular power button, I can mount the reset button to clear CMOS pins since dells don’t have a reset button
The 7850 I have has no shroud or fans so I hotglued a fan on it, the thick dell fan is purely there to prevent an Error message at boot, will hotglue it on the GPU later
since the IO panel was built into the case there is none currently, I think they sell some custom ones on ebay
this thread helped me out and is the source of one of the pictures
build functions as if it were a normal PC if I not had the dell power button, jumped the front panel, used dell fans in both headers would have halted boot and prompted F1
(Note: I would never sell a PC like this, I only do ghetto stuff to my own hardware, he’s just using it because its free)
