Hello, my GIGABYTE Z77x-UD3H Motheboard boots then shutdowns completely then boots again.. is that a sign of my boards death? i'm using Cooler Master GX 750w Bronze 80 Plus Power Supply by the way...
Disconnect your GPU then try again. If it doesn't work try again with only one stick or RAM. Or, deassemble your build and try it outside of the case.
Hey man, i did the two steps also my friend was watching me do it on the Skype's stream and he told me it's the motherboard's issue and i agree with him i noticed the motherboard is pretty much facing some annoying malfunctioning which can easily cause to decrease the SSD's lifespan faster and decreases the speed slower. and that is not a good thing you know. i've reformatted everything and Resetted the CMOS and the BIOS manually still the same... the motherboard is facing a power delivery issue but thank's for you reply... highly appreciated!
