Gigabyte X870I Pro Ice Wifi/LAN issues in Linux help with installation!
I have the Gigabyte X870I Pro Ice and it has issues in Linux when it comes to networking and apparently it is a known issue, but reddit seems to have found a fix and I was wondering if someone could translate this to me in ENglish…I am a Linux novice there are so many terms and jargon I am trying to learn. I’d really like to try and get these internet issues fixed before exchanging the motherboard.
I am at work and I can’t paste the contents of the link
https://www.reddit.com/r/linuxhardware/comments/1gu1uw2/solution_gigabyte_x870i_aorus_pro_ice_miniitx/
If someone could tell me what I am supposed to type into the linux command prompt…i believe it is called flatpack I would be grateful.
I know these questions seem dumb, but I will figure it out…eventually.
Kernel 6.13 should have these drivers merged. What distro are you running?
Bazzite
