Hi All, Im having issues with my current setup and I was hoping to get some additional help with it. I current have the following:
CPU: Threadipper 3970x
Motherboard: Gigabyte Trx40 Aorus Master
Ram: 64Gb
PSU:Apevia ATX-PR800W Prestige 800W 80+ Gold(I know its garbage)
GPUs:
pcie slot 1x16 (radeon pro wx 5100-PCIe® 3.0 x16)
pcie slot 2x8 (nvidia geforce 210-PCIe® 2.0 x16)
pcie slot 3x16 (nvidia quadro k4200-PCIe® 2.0 x16)
pcie slot 4x8 (gc titan ridge - PCIe® 3.0 x4 “from gigabyte designare trx40 rev1.0” i have this mobo too)
pcie slot slot x1 wifi card/bt card
What do I want this setup for?
I planned to have a linux host(manjaro) with virtual machines( windows and macos) using vfio.
Issues I’m having:
Bios: Starting from the bios/posting i want my geforce 210 (which is a 2.0 pcie i believe) to be my manjaro display. I have configured in the bios ( version FA6) to set to pcie boot slot 2(which is the geforce). Sometimes it works with 1 extra gpu (either nvidia k2000 or wx 5100 in a slot and no other gpus) and sometimes it doesn’t with all gpus. Bios want to grab display from display port gpu or again with all the gpus bios will reset the CSM which will give me an error post code “d4” i have enabled above 4G Decoding btw to try to overcome this code but CSM must be off and fast boot but sometimes bios reset this I’m thinking because the geforce 210 doesn’t have display port and is 2.0 pcie. I have also tried placing the cards in different slots as well as replacing geforce 210 with a nvidia quadro k2000 in addition to k4200 and wx 5100 but bios gives me post code “0E” which i believe is sleep code i don’t know. I have also tried bios version F4A same “d4” error.
In manjaro I current am using manjaro.vfio helper script…“https://www.google.com/url?sa=t&source=web&rct=j&url=https://github.com/pavolelsig/passthrough_helper_manjaro&ved=2ahUKEwjKuO6g-Zj4AhXjoWoFHW3rAMEQFnoECAgQAQ&usg=AOvVaw3GZN13qVaylcgyGl-1BHTN”
I thought about binding or blacklisting the k4200 and wx 5100 in the grub but I’ll get no display.
If i need to post additional info i will but please someone give me some guidance thank you.
