I found a good price for a 7870--- http://www.newegg.com/Product/Product.aspx?Item=N82E16814125418
Now that i have it I was wondering if I could use these mac dp to dvi adapters.
http://inlandproduct.com/prominidisplayporttodviadapter.aspx
Also, any reviews on the 7870? i cant really find much information on the card online and it seems to be sold out all over the place. Thanks!
sapphire and his make better 7870's
Commissar that wasn't his question, and gigabye is a fine company, Alav I don't see any reason why it wouldn't work but I can't say for sure, I've had lots of issues with adapters made by the same gpu vendor not working before. But that should work I don't see a reason why not, yet...
Lol no wonder it was $200. What about those mini dp to dvi adapters? Any information about those?
ooh, didn't see that you already had it....
check out reviews on newegg, see what looks best...
Just grab it. It should work fine.
I'm a little confused as to why you want a display port adapter though when you already have a DVI port on the back of the card and every monitor out there is going to have DVI.
you never know when you need an adapter from display port. thats the only reason. plus if i wanted to try triple monitor, ill need the adapter. Unless there is something that i dont know about..
