Gigabyte H87N Help!
Hey I recently purchased this motherboard used: http://www.newegg.com/Product/Product.aspx?Item=N82E16813128626 and it didn't come with the included antennae. I was wondering if there's a third party external one that would work with this motherboard?
Edit: On closer inspection several of the cpu pins are bent so I'm going to return this board and save up the extra money for an impact. Sorry for any inconvenience you may have experienced by clicking on this post. (btw if you have any itx mobo suggestions I'd be happy to hear em :)
Actually I'm personally getting this board, and as long as if you're not overclocking I'd go with this board over the impact. and if you're only doing moderate overclocking I'd go with the Z87 variety of this board, everything is the same except it has better OC support. What you had was just bad luck, it happens.
I ended up getting a cheaper msi board, and putting more money towards other things. Thanks for the advice Hikage.
