Can anyone tell me which one is better for 3570K? just wandering which is best from these three motherboard...
Both the Asus and the Gigabyte boards are good, I personally would not touch an asrock board as a friend of mine had a z68 extreme4 that is totally fried.
Another of my friends has almost exactly that gigabyte board and is LOVING it, he also has a 3570k in it.
Personally I would go the gigabyte.
If you have more questions my email is [email protected]
hahaha, it is you again hiyayhi, thanks for commenting my post :) maybe i will email you another time when i have any question on my mind.
Im running a Z77x-UD3H which just has a few extra little tid bits over just the D3H, but the overall board is solid and the Ultra Durable features plus the dual BIOS definitley makes it worth it.
yea iv got the ud3 and its really good
Thanks for your comment guys :D Btw did you guys do overclock with your motherboard?
I havent Oc'd my CPU yet but the Gigabyte poards have a solid power Design and tons of power options with the 3D Power, and with the Digital power Control the Voltage regulation is really good too.
Asrock extreme 4 or Asus p8z77-lk
