OK, new board to replace Asrock unit I killed with AZ Summertime. I update bios for the 2400g to work, all went well. After light use for 2 days suddenly USB’s are getting overvolt every time I plug anything into any USB port. I am using a hub plugged into my PCI-E to USB 3.1 card and that is working fine. Just wondering whether to RMA the board or if this is a Windows thing?
Have you checked the BIOS? That board has an option to feed more juice (or turn off all power) to the front USB3.0 ports and the two yellow ports at the back.
Also which of the 3 boards? K5, 5 or K7?
First step I would clear CMOS/reset UEFI settings. If that doesn’t help maybe contact their support, haven’t heard of this before to be honest.
I agree. Clear CMOS and see what happens.
If that does not fix the problem, locate the dual BIOS switch on your board, switch it, and boot from the backup BIOS and see if that has issues.
AFAIK All modern gigabyte boards have the Dual Bios functionality that Gigabyte started (as far as I know they were the first, might be wrong) which allows you to switch to a secondary BIOS chip in case something went wrong with the first one.
Solved, I think. Went into BIOS and looked for the things you guys suggested. No place to adjust the voltage to the USB that I could find. I did reset the defaults and found that this budget board does not have the Dual BIOS feature. I rebooted and all the USB now works, except the front panel. I still need to figure that problem out but I can now get cables off my desk and move on to fighting windows. Thank you for your help.
That would very much surprise me, which board do you have exactly? Because all the X370 boards on Gigabyte’s website advertise a DualBIOS.
/edit
Just noticed that this one seems to be the only one without it:
My board is the GA-AX370-Gaming rev. 1.0. After some research, I read the box, it does indeed have the dual bios. The board is functioning fine this morning so I still think it is still solved, maybe.
