Guys i have a small problem.
I have an Aorus x570 Pro (non wifi) where i have latest Esxi 6.7 and on it i have an HPE P440 4GB FWBC raid controller that i bypass it to a Server 2019 VM.
The controller is bypassed correctly but there seem to be a speed problem. The Smart Array configuration software of HP says in that VM the bellow info
" Smart Storage Administrator
- Controller Hardware Information
Controller | Smart Array P440 |
Slot | 0 |
PCI Address (Domain:Bus:Device.Function) | 0000:13:00.0 |
Negotiated PCIe Data Rate | PCIe 1.0 x8 (2000 MB/s) |
Hardware Revision | B |
Firmware Version | 7.00 |
Number of Ports | 1 (Internal only) |
Controller Memory Module Size | 4096 MiB |
Battery/Capacitor Pack Count | 1 |
So it seems that the controller works at PCIe v1 X8 which means 2000MS/s maximum speed.
Now if i reboot the whole box in a windows 10 installation that i have, the same software from HP that controls the HBA says this info
Slot | 0 |
Negotiated PCIe Data Rate | PCIe 3.0 x8 (7800 MB/s) |
So its obvious that something is happening when i passthrough the controller in esxi but i dont know what to check. As matter the speed, in that controller i have 4x1TB Samsung Sata SSD in Raid10 and 4x4TB HDD Sas in Raid10 and in tests (i use the Windows Storage Spaces with the Tiering feature) i saturate the 10GB Lan card i have on the machine in both read and write.
Anyone has any clue why this is happening? i mean it doesnt seem to be a speed problem but its strange.
