Gigabyte A520I AC, trash tier?
Is it some cost optimized bullshit to squeeze money out of the last bit AM4 market? Or is it simply basic and long term adequate and won’t fail within a year? I’m thinking X3D, overclocking isn’t worth bothering with anyway.
A stranger asked me about building a PC for them. If it was somebody I knew, might do some min-max obscure used parts sourcing.
Buildzoid reviewed this board but IIRC it was before the release of the 5800X3D. I couldnt recall the exact cpnclusion but i think it was adequate enough for this trash tier
was the A520M H
I think is more than good enough for an X3D chips. They don’t use a lot of power and even a 5800X3D at stock voltages doesn’t pull too much power. A 57/5600X3D is gonna sip power.
Also most 5800X3D take huge negative PBO offsets so they end up using almost the same power (if not the same) as a 65W TDP AM4 part.
Other than the VRM failing I don’t see what else could fail on it that’s constantly stressed.
I have data of my 5800X3D under load, if you need those.
I did a quick watch of Buildzoid’s video and he thinks AMD might have leftover some overclocking features inadvertently. At any rate he thinks this will be decent or be even good for memory overclocking because of its dual slot RAM nature. I think there is a follow up video where he does the actual overclocking.
All I’m worried about is not getting an Asrock experience. The only board I got from them, died after 6 months; same with the replacement.
