Gigabyte 990fxa-ud3 not posting
I have a gigabyte 990fxa-ud3 that will not post, when I start it, it emits continuous short beeps, I found the beep codes and it means power failure. I tried a different power supply and no joy, I tired different sticks of RAM in each of the four DIMMs. Any ideas would be appreciated.
My Specs:
Power Supply: Antec EA-650 650 W Max
Motherboard: Gigabyte 990fxa-ud3
CPU: AMD Phenom II X4 975
RAM: Corsair Vengence 8GB
GPU: Gigabyte 7950.
Wow spam
Anyways, is the 24pin properly seated and the 8 pin CPU power? Same goes for the 7950 are the 2 6pins plugged in and properlly seated?
yes did you connect the 8 pin or 4+4 pin cpu power connector the right way in? so that the clips matchup with nodges? some psu´s you can put the 8 pin connetor the wrong way in..
Yes of course the 8 pin is connected, nothing happens when its disconnected and the 7950 is connected properly.
