Hi guys,
some time back i saw the same or similar mouse way back on one of the TEKs. … recently i’ve found it on dealextreme.
It looks pretty rad for 6$, but the sensor seems to be a little weak, but … i’ve taped up the sensor, and it isn’t half bad now
Have you done any similar “rgb on cheap” mods?
When you say the sensor was weak did you mean the mounting and that messed up the performance? I see the tape there but am not quite understanding.
I suck at physics so i don’t really know, but it seems like the two bright RGB diodes were messing it up. Not a great sensor overall tho, but hey it’s $6
