Getting ready for my first build!
This will be the first time I build a computer, and I finally put together a list of parts with what I've learned from lurking on forums and watching Youtube videos. anyways, I was hoping so could take a look and share any opinions on it? Something i should change or dont need? Don't really want to spend any more than $700.
http://pcpartpicker.com/p/szBhGX
CPU: AMD FX-6300 3.5GHz 6-Core Processor
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler
Motherboard: ASRock 970 Extreme3 R2.0 ATX AM3+ Motherboard
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1600 Memory
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: EVGA GeForce GTX 760 2GB Video Card
Case: NZXT Phantom 410 (White) ATX Mid Tower Case ($89.99 @ Amazon)
Power Supply: Corsair CX 500W 80+ Bronze Certified Semi-Modular ATX Power Supply
Operating System: Microsoft Windows 8.1 - 64-bit (OEM) (64-bit)
What country are you from ?
If the nzxt case isn't very important for you, there are cheaper, still viable alternatives, which would allow some more money to go towards hardware.
If the case has good airflow (which it has, in this case) there's no reason to go with a blower type cooler, because it will have to work harder too keep the temps low. Go with a dual fan design. You might also want to take a look at some R9 280's.
As for the motherboard, the only compelling reason to go with the Asrock 970 Extreme3 instead of the Gigabyte UD3P  is the current promo. If you can squeeze an extra $15 - $50, it would be nice.
The intel build is the most expensive one just under $760.
 http://pcpartpicker.com/p/4pjN23    - $757- changed the cpu and motherboard, case, GPU (XFX R9 280 double dissipation) and added an SSD
 http://pcpartpicker.com/p/pDbCgs  - $730 - changed the motherboard, case, GPU (EVGA GTX 760 ACX) and added an SSD
 http://pcpartpicker.com/p/6Y6qWZ - $715 - changed the motherboard, case, GPU (XFX R9 280 double dissipation) and added an SSD
 http://pcpartpicker.com/p/QY6qWZ - $705- changed the case, GPU (EVGA GTX 760 ACX), added SSD
 http://pcpartpicker.com/p/wRpmQ7 - $690 - changed the case, GPU (XFX R9 280 double dissipation) and added an SSD
I added a more reliable HDD and a better GPU.
http://pcpartpicker.com/p/9kddvK
-LinuxForYou
