Getting first homelab (EliteDesk 800 G4 Mini), some advice on starting out?
Hello all,
I recently bought an EliteDesk 800 G4 Mini i7-8700T (16GB) , and wanted to ask for some advice based on the services I want to run on it.
Just had the following questions:
  1. Should I get a 90W or a 150W charger for it? (I don’t plan on adding much more stuff to it down the line… but maybe there’s something I’m not thinking of).
  2. Given the following services I want to setup, is there a certain way I should approach it? Or some of them that I should do first? Or any general tips?
Services:
  • Syncthing (to have all my devices / laptops sync their Joplin / Obsidian databases to one place)
  • Nextcloud (to replace google drive, etc, and have a private cloud)
- PiHole
  • Plex(?) - just light use or to experiment though I think. I don’t watch much TV / movies. Optional.
  • Private VPN
  • Reverse Proxy
  • Firewall? (not sure how necessary / complicated this is)
- Hosting own website (might be more of a security risk / hassle than it’s worth. Just a potential idea)
  • Tandoor (recipe website)
  • AI Services
  • Running scripts at night, doing website scrape jobs at night, or any type of script jobs I might need done. Maybe pulling data from APIs, to feed into more powerful PC in my room during the day.
More Background:
  • I do plan on building a trueNAS from a old tower case I have, and that one would be the serious trueNAS / backup server / Plex server.
  • This mini PC I plan to use more as a service that will always be on 24/7 (mostly as a central hub for Syncthing and Nextcloud, and also to use as a reverse proxy and private VPN).
  • My main PC in my room is quite powerful, and I want to use that one for learning LLM’s and any heavier jobs / computing.
  • I got my Sec+ cert not too long ago and looking to experiment and learn stuff to help land a job in the field (My background is Mechanical Engineering but I’m looking to switch).
Thank you in advance for any insights and tips!
I see no need for this.
What technologies do you know? Do you have any experience with Docker containers? K8S? Linux? Proxmox? Ansible? Terraform? Etc.
I don’t know what kind of job you want to land, but learning basics of firewalls sounds like a good idea. Take a look at opnsense.
Thanks Mietzen. I know some Linux, I messed around with it many years ago. I know a bit of programming (Fortran, Matlab, VBA), but just the basics. I have the Sec+ cert, so I know the basics, just trying to implement stuff now to learn hands on.
Anything in cybersecurity or networking really. If you have any suggestions on the best career path however, I’m all ears. I’m curious where the best opportunities are within cybersecurity.
I’m not a security guy, my background is more in DevOps so my opinions are a bit biased.
But from what I know, I’d say learning shell scripting and Python definitely won’t hurt. Depending on the direction you want to take, Windows tools like PowerShell, Active Directory, and Windows Server Administration could also be valuable. The field is huge, you need to decide what you want / are interested in.
Back to your main question: I wouldn’t mix a productive home setup with a learning environment.
If you want both a learning environment and some productive services, I’d recommend setting up Proxmox on the HP. Do you have two NICs or a VLAN capable switch? If so I would start with creating an OPNsense VM as your main firewall.
From there, you’ve got a few paths you can take:
  • LXC containers for services: check out community-scripts for ProxmoxVE. In my opinion, you won’t learn much here, as the scripts are pretty guided. But you can learn from reading the setup scripts.
  • One Linux VM running Docker/Podman: manage everything with Compose files. There are tons of examples and tutorials out there. Great to learn containerization and the mindset behind it. Take a look a traefik as revers proxy using lables.
  • Separate VMs for each service: this is closer to a bare-metal install experience. You’ll learn a lot, but it’s less efficient and you will need to read the docs.
  • Separate LXCs for each service: similar to VMs but more efficient, though hardware passthrough is sometimes a bit tricky (e.g., for hardware encoding/transcoding).
Once you’ve got the services running, you can use LXCs and/or VMs to build an isolated learning environment that’s separated from your main network. An SDN is great for this. Use templates, backups, and snapshots so you can easily tear down and rebuild everything. You might also want to look into automating deployment and teardown with Terraform or Ansible.
Some other thoughts (maybe to advanced right now):
  • Check out GitOps, depending where you want to go, this might be a principle you want to learn
  • Take a look in the whole field of monitoring, you can try this out on some of your services using prometheus and grafana. You might also want to look at jaeger to collect traces and dip your feet into observability, but you would have to create some services where this is applicable
  • I can’t give you real advice on the whole field of networking, but you might want to take a deeper look into it
Narrowing this down will help you a lot in many ways. Are you looking to go the SOC (security operations center) route, Red teaming, Network admin/engineer, etc. They are all very different skillsets and certification paths and would require very different homelab environments to get a good playground for.
What excites you the most right now? What areas do you find yourself either researching or playing with in your spare time?
Thank you Mietzen and Stin - I’m most interested in automation, blue team (defense) / protecting a system, and also in investigations (red teaming). Investigations as in maybe monitoring data, or breaking into a system to monitor data, that type of thing - to better understand blue teaming.
Right now besides trying to setup a private cloud (Syncthing and Nextcloud probably being the first project on the homelab), I’m also quite interested in the red team aspect of monitoring data (I believe that would be through Wireshark and adding a VLAN-capable switch?), to see if anyone has infiltrated my system, or how a potential hacker would see data across my system / understand how hackers extract valuable information.
Before you build out the homelab for cybersecurity training I’d reccomend spending a month or so on tryhackme or hackthebox fist. This will let you try out the different sides of red and blue teaming and see just how much you enjoy each aspect. Tryhackme has some planned out courses that will give you a very broad overview of the skills and day to day of both SOC and Pentesting. May be a nice place for you to start. I haven’t been on hackthebox in a long time but it used to be fun CTF based stuff.
