Hello, Everybody. I encounter a problem when I using my guest.
I booting my guest without HDMI primarily, Then I add it, but my guest is be rebooted.
To know what cause it, I do it again, especially I check my guest is running normal or not with “ping” before plugging, that’s well.
What I was suffer? can you help me solve it?
Following message is detailed!!!
Guest: window 7 profession
Linux: Ubuntu 1604
Qemu:1 v2.11.0-rc0
Libvirt: 3.9
method of booting: virsh start myGuest1
method of plug HDMI: virsh qemu-monitor-command myGuest1 --hmp ‘device_add driver=vfio-pci,host=01:00.0,xvga=on,multifunction=yes’
phenomenon: after plugging, my Guest is failed to check with “ping”, for a while, my display is light and load windows.
expect: my guest is running when I plug HDMI, it seem that hot add a device
