General Use Computer Build
Hey all,
I have been asked to build a computer for general use, including but not limited to, web browsing, microsoft word, ect.
I have not been keeping tabs on new parts over the past three years, so I am hoping that you folks can enlighten me on a good combo.
Budget is loosely $700. Don't want to charge too much for it since they wont need a lot of power. I am thinking $500 will be enough.
My original idea was to go with the quad core FX from AMD, however, the six core FX-6300 is only $10 more at the moment.
I know nothing of intel chips in regards to how they compare to AMD other than the fact that they are a bit stronger in productivity, which this computer does not require.
I am only looking for a good CPU+MoBo combo, I already have a decent idea as of what to get for the remainder of the parts.
If the fx-6300 is a good choice, then I just need a mobo recommendation as I am having trouble finding one I like.
Additionally, if you know of a site that can update my information on parts, please link it.
Short version:
Need CPU and good MoBo for general purpose computing. Try to keep it under $300, I don't need overkill.
Thanks for taking a look and possibly commenting!
Is there a case size limit? You can build a really small PC so long as you don't have a need for a GPU.
I am considering an FX-6300 paired with the ASUS M5A00FX.
@Calvus There is no limit but I figured I would go with a larger computer b/c small MoBos are more expensive(?)
Here is my sub US$500 build for a general purpose PC. It is the full build but I used the CPU/MoBo combo for another SFF general computer that I built.
-I don't know jack about AMD CPU's or chipsets
Might help if you link it, I unfortunately cannot read minds :P Or else I am blind and you did link it.
Crap, lol. Luckily all I had to do was paste it.
http://pcpartpicker.com/p/BF7c6h
That looks good to me. Too bad I know nothing of intel to compare them. About how fast is it? Can it handle having multiple programs open at once? about how much would the next-best cpu cost?
It is 3.7GHz 2 core w/ hyperthreading, so effectively 4 cores. It multi-tasks just fine, multiple browser windows, watching video and working with spread sheets.
Oh ok, I think that is about what AMD's quad cores are. It is fairly surprising, a 480gb ssd now cost less than my 120gb ssd cost me a few years back
I would personal do something like this and I would stick to Intel because if you go with one of the FX chip sets you will be stuck with ddr3 ram and you would need to get a gpu because those particular chips don't have integrated graphics.
http://pcpartpicker.com/p/jXRfMp
For general use I'd also go with Intel. I find that stronger single core performance just overall feels snappier than something like my Athlon X4 860k, even with a ssd. And as shadow stated, you can use integrated graphics on the Intel side.
Also, 8GB is probably plenty for a build like this. There's no need for 16gb.
PCPartPicker part list: http://pcpartpicker.com/p/yGkkvK
Price breakdown by merchant: http://pcpartpicker.com/p/yGkkvK/by_merchant/
CPU: Intel Core i3-6100 3.7GHz Dual-Core Processor ($110.99 @ SuperBiiz)
Motherboard: MSI H110M Pro-VD Micro ATX LGA1151 Motherboard ($47.98 @ Newegg)
Memory: Crucial Ballistix Sport LT 8GB (2 x 4GB) DDR4-2400 Memory ($35.98 @ Newegg)
Storage: A-Data Premier SP550 480GB 2.5" Solid State Drive ($108.99 @ Amazon)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case ($29.99 @ Newegg)
Power Supply: XFX XT 400W 80+ Bronze Certified ATX Power Supply ($22.98 @ Newegg)
Total: $356.91
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2016-05-21 23:03 EDT-0400
Person who wants this PC is set on having a slim tower itx.
Here is my build so far, I just need a slim optical drive
http://pcpartpicker.com/p/wkb4t6
@Some_Tech_Noob
Will probably use your build for the other person who needs a new PC
Looks pretty good.
Get and Intel i3 NUC: https://www-ssl.intel.com/content/www/us/en/nuc/nuc-kit-nuc5i3ryh.html
a monitor, and a roll of duct tape. Your done.
Oh and Ubuntu-gnome 14.04.04: https://wiki.ubuntu.com/UbuntuGNOME/GetUbuntuGNOME
You don't need windows for web browsing and document reviewing.
