General Graphics card question
What is the best preforming 7870 gpu for gaming?
I would suggest a HIS for overclocking, or ASUS... they're both good
All 7870 are created equal in terms of the core they use. Though there clock speeds do vary.
For gaming, I'd look for one with at least 2GB of RAM so that all the textures can be loaded properly.
As for overclocking a GPU, I personally like the XFX cards due to the warranty not becoming invalid if you overclock. Though as thetb0 has said Asus and HIS are also good OCers.
Good Coolers are also a must, cause the stock designs can be very loud.
If you have the budget, also look at the Tahiti LE version of the 7870 as it has approx 300 additional stream processors on top of the regular edition.
- zanginator
Hey guys i have a radeon 7870 by HIS is a top temperature of 70C alright im getting a new fan in soon and i plan to put it right next to it on the window since i have a cheap case i love to cut holes and modf it to how i want is that temp alright and yes i would say go with HIS i love mine just have a question about tmeps.
Pretty good article on the Tahiti LE right here.
http://www.tweaktown.com/reviews/5120/powercolor_pcs_radeon_hd_7870_tahiti_le_2gb_myst_video_card_review/index2.html
