Geforce GT 610
I'm planning on buying this little guy
Brand new for £39.99
It's a 300w Thingy
My power Supply is 305w
I dont have any other Hardware installed
I'm planning on buying a higher PSU in Feb when i get some money
Would i be alright to use this Graphic Card? for a while...
Or will my motherboard break
Excuse my noobishness...
Share your wisdom
So long as you do not have 100 hard drives you should be fine. It's hard to say for sure without know your full specs....
download and run CPU-z, hit validate, after it posts on your browser, paste the link here, I can tell you what you can get with what you have
Did some poking around and it seems the Intel HD 4000 easily beats the 610 in nearly anything. It is actually a GT 520 with a different coat of paint on it. Which was not too dissimilar to the G310 except that it supported Direct X 11.
Please do what gigabuster has told you to do. Who knows you may just save $40!
I wouldn't bother with a 610 unless you're using it for an HTPC.
