I have a GeForce Experience program on my computer. I can't get the program to open up properly. The icon in the taskbar will show the program is open, and when I hover my mouse over the taskbar icon that little "preview" mini-window pops up above it with just the GeForce logo in the middle of the window, but the program will not open up fully on my desktop. This happens in all efforts to open up the program, whether it be from the desktop icon, taskbar icon, file location, etc. Any ideas?
Just joined this site to reply to this post.
I managed to figure this out thankfully, and I hope that even though your post is a bit old now, that I may still be able to help if you haven't figured it out already.
If Geforce Experience does what you described above again, hover your mouse over the icon in the task bar like you mentioned, then right click on the preview image that pops up and choose "Maximize".
Hope it helps!
Thanks for the reply. I got it to work a few days ago, can't remember how, maybe I accidentally did just what you said.
I have another question. I am running 2 monitors. Ben Q 1920x1080 and an HP with is maybe 1200x900. I have the Ben Q set up as the "main" monitor.
In windows control panel>hardware and sound>display>adjust resolution settings, I do indeed have the Ben Q set at 1920x1080.
Under "My Rig" in GeForce, it lists my current resolution as 1536x864,144 hz. Where is GeForce pulling the info from?
Thanks both of you so much!
I assume you have figured it out but if you havent you can set a custom resolution in the nvidia control panel to 1200x900 or whatever you need!
