Pc specs: http://uk.pcpartpicker.com/user/12stiggy12/saved/rNcMnQ Cpu is oc'ed to 4.6ghz, and ram is at 1866mhz, gpu is oc'ed +80mhz on the core and +415mhz on the memory
Hi everyone. Whenever i play Garry's mod i get really low fps, gpu usage and my card sits a stock clock which is about 1084mhz causing me to lag stutter and generally make the game unplayable as this puts me with a massive disadvantage. This happens on all servers i go on including servers that used to run great on highest setttings with Radeon 6670 that was in my old pc. I found that my card is overclocking in the main menu but not in game which is very frustrating. My temps are fine and my cpu usage is normal.
no no i built a new pc from scratch and ive reinstalled the drivers a number of times including wiping my hard drive and performing clean installs nothing works.
