I will be doing a build actually in a few days as of posting this. I should have enough money to start.
Here is the build: http://pcpartpicker.com/user/GamingFTW/saved/3lfV
I will also be posting a build log as a blog post and I will also be doing a few videos on tutorials.
It may not say 3k but the monitor I will be getting will pretty much make it 3k. The monitor is an Asus PA279Q, http://www.amazon.com/ASUS-PA279Q-27-Inch-Screen-Monitor/dp/B00DX64DBU
I just wanted to post it here just to make sure its pretty good and passes your "standards" lol.
Let me know if I should change anything.
You might also be thinking (how u get dat money), and well I'm not at liberty to say. But I will say it is out of my own pocket.
I agree. Looking at the monitor, it leaves him with a budget of $2200, so there's plenty of room at add one of those, except for the 780 Ti.
Of course, there is much to be said for saving a couple hundred dollars, especially since the 280x will still be a decent card for 1440p.
OP, did you ever consider getting a Korean 1440p monitor? It would be a lot cheaper, although support and reliability may not be as high. Still I believe you can get them in the ~$300 price range.
Fair enough. I wish that test included more SSDs though since it didn't include any from PNY, Mushkin, Crucial, OCZ, or A-Data, and those are moderately common brands on the market. Well except for PNY maybe, but I don't keep track of everything like that.
I agree, I would like to see a test of the OCZ. The way that the Corsair SSD just increased in speed and is still fine after 600TB's of writes is truely amzing.
620W BRONZE. Is way too little for that. I always say 33% more than the recomended, and really? bronze? Come on... 1:50 https://www.youtube.com/watch?v=yhUnIx6zF_E#t=110
But I wanna try AMD. I love multitasking, I usually have 30+ tabs at a time so I would benefit from the extra cores.
Yeah, it just went out of stock on Sunday but you can get it on ebay, which I will be doing because it doesn't matter when the RAM comes with a lifetime warranty.
I like headroom in my power supplies. You DON'T SKIMP ON POWER SUPPLIES. I can't stress that enough....
Your overkill and my overkill are two different things. I plan on upgrading the shit out of this. I and don't want the first thing I have to upgrade being my power supply.
Yeah, I was initially interested in the OCZ Vector 150 since it appears to be a cross between a consumer and an enterprise SSD performance and reliability wise, but I can't find too much info on it other than speed and power consumption.
If he wants to go overkill on his PSU let him lol!
I went overkill on mine- It will run better by being less stressed overall and leave plenty of room for future upgradablility-
Also- vmN is right, At this price point you might aswell get the intel. It's a very solid part and multi-tasking is not a real reason for getting 8cores- the i7 has your 8 virtual cores and MUCH MUCH better IPC, while being a new better archetexture and using much less power
